I am using ulead videostudio 6 to capture my video and my os is xp. I have plenty of hard drive space, but i keep on getting errors that i am out of memory. I have researched this and understand that it was a problem with 98 and 2000... but I haven't seen anything about having a capture limit on xp. how would i work around this? if i have to segment the video, i suppose that it's ok, but how would I link them together to burn them to dvd? any help would be appreciated! :P
with both win2000 and xp - you would have to format your drives as NTFS to get over the fact that fat32 formated drives are limited in file size..
Go to the help section and type NTFS in search. You run it from the command prompt in XP. Don't quote me but it's something like
convert c:ntfs Look in the help area to be sure. It does work. -
hi,
thanks for all the help you have been giving me, but i do still have a problem. my hard drive is already configured to ntfs................. any suggestions?
AI researchers think 'Rascals' can pass Turing test
By Epicurus8a in forum Off topicReplies: 2Last Post: 15th Mar 2008, 15:51
